3.4.1 Build 5400
- Removed need of elevation dialog when starting Uninstall Tool from desktop shortcut and context menu for exe/msi setup file
- Improved stability of shell extension (utshellext.dll)
- Improved overall stability by bunch of small improvements and bug fixes (including crashes)
- Switched to Visual C++ 2013
- Fixed number of false positive registry keys that could be captured by Install Tracker
- Fixed problem that happened after removing a traced program entry - it appeared in the list again
It's a starting point to new release - 3.5.
Download: http://www.crystalidea.com/downloads/un ... _setup.exe
Portable version (if you own a license): http://www.crystalidea.com/downloads/un ... rtable.zip
Uninstall Tool 3.4.1
Re: Uninstall Tool 3.4.1
3.4.1 Build 5401
- Fixed crash introduced by VS2013 compiler and Execryptor in unregistered x86 version
Download now
Download now
