trial regular product, purchase portable - install tracking?
I'm probably going to be buying the portable license, so I can use the product on all my pcs. Is it actually a different download than the trial version? Concerned I might have to uninstall trial and wondering how that would affect the tracked installs.
Re: trial regular product, purchase portable - install tracking?
Yes, portable version is a different download. Read more at:
http://www.crystalidea.com/uninstall-tool-portable
Yet again an incomplete answer missing the point.
The thrust of the question is, what happens to the tracked install data from the trial? Is it lost because a portable version (now confirmed as different code) is installed?
No, it won't lost. Tracked data is shared between normal and portable versions.
