I have uninstalled, restarted, redownloaded and reinstalled. The issue is still there.
Everything seems like it is going to work, and it installs correctly. Then the application launches and I see the icon in the system tray, but I cannot access to window. When I hover my mouse over the icon, it shows me a white window that has no details. I cannot see if it is running or change any of the settings.
This is a very new install of 8.1 without much else besides Steam.
It used to work and worked for about a week, then it just stopped working. Nothing new was installed in that time.
edit: It used to do nothing when I clicked the icon, now the icon disappears.
Please help!
- Thinkbox
App Not showing up on 1.2.1 on 5K iMac in Windows 8.1
Re: App Not showing up on 1.2.1 on 5K iMac in Windows 8.1
thinkbox
Reboot and restart the app.
I have restarted and rebooted maybe 20 times.
I have uninstalled, wiped the folder, and reinstalled, rebooted and it still has issues.
It ran for about 2 weeks without an issue and now all the sudden it just won't work.
Can you please record a screen capture video?
http://i.imgur.com/AyUlfk2.jpg close up on the application preview window
http://i.imgur.com/Wo7hR2L.jpg - application when I hover over the preview window
edit: I only really use this windows partition (which pushes the GPU well over 100 C if I dont start the fans at full power early on) so I dont have any screen cap software installed. Is there something free you can recommend?
thinkbox
Please try to remove this registry key:
HKEY_CURRENT_USER\Software\CrystalIdea Software\Macs Fan Control
That did it!! Than you so much for the support! It really makes a difference!
thinkbox
Could you please provide us with screenshot of the main window?
And technical info from Preferences/Diagnostics.
I had to clear the registry and re-install again. Seems to just go bad every week or so.
Here is a screen shot
http://i.imgur.com/X7wWtPi.jpg
Macs Fan Control 1.2.1
iMac15,1
Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz[100]
Windows 8.1 x64
Main-min{1200}curr{1200}max{2854}mode{2,TG0D,80,99}
TA0P (Ambient) - 20.875, 20.875
TA0V () - 28.2656, 28.2656
TA0p () - 40.875, 40.875
TC0E () - -1, 214.395
TC0F () - -1, 216.465
TC0J () - 2.07031, 2.07031
TC0P (CPU Proximity) - 54.125, 54.125
TC0T () - -1, 255.922
TC0c () - 55, 55
TC0p () - 54.125, 54.125
TC1c () - 55, 55
TC2c () - 53, 53
TC3c () - 54, 54
TCGc () - 56, 56
TCSc () - 55, 55
TCXR () - -1, 212.453
TCXc () - 56.4531, 56.4531
TCXr () - -1, 212.453
TG0D (GPU Diode) - 68, 68
TG0E () - 68.0625, 68.0625
TG0F () - 69.7422, 69.7422
TG0J () - 1.67969, 1.67969
TG0P () - 48.375, 48.375
TG0T () - -1, 255.992
TG0d () - 68, 68
TG0p () - 48.375, 48.375
TG1P () - 57.875, 57.875
TG1d () - 63, 63
TG1p () - 57.875, 57.875
TG2P () - 53.625, 53.625
TG2p () - 53.625, 53.625
TG3P () - 58.375, 58.375
TG3p () - 58.375, 58.375
TH0A () - -1, 129
TH0B () - -1, 129
TH0C () - -1, 129
TH0F () - -1, 129
TH0O () - 9, 9
TH0P () - -1, 129
TH0R () - -1, 129
TH0a () - -1, 129
TH0b () - -1, 129
TH0c () - -1, 129
TH0e () - 1, 1
TH1A () - 54.125, 54.125
TH1B () - 53.875, 53.875
TH1C () - -1, 129
TH1F () - -1, 229.125
TH1O () - 9, 9
TH1P () - -1, 129
TH1R () - -1, 229.125
TH1a () - 54.125, 54.125
TH1b () - 53.875, 53.875
TH1c () - -1, 129
TL0P (LCD proximity) - 37.8125, 37.8125
TL0V () - 34.4961, 34.4961
TL0p () - 37.8125, 37.8125
TL1P () - 39, 39
TL1V () - 34.1562, 34.1562
TL1p () - 39, 39
TL1v () - 34.1562, 34.1562
TM0P () - 46.625, 46.625
TM0V () - 48.3984, 48.3984
TM0p () - 46.625, 46.625
TM1P () - 38.5, 38.5
TM1a () - 57.4375, 57.4375
TM1p () - 38.5, 38.5
TM2P () - 42, 42
TM2a () - 50.1992, 50.1992
TM2b () - 52.8555, 52.8555
TM2c () - 51.3164, 51.3164
TM2d () - 58.7695, 58.7695
TM2p () - 42, 42
TM3P () - 44.125, 44.125
TM3a () - 54.7695, 54.7695
TM3b () - 52.5078, 52.5078
TM3c () - 52.5078, 52.5078
TM3d () - 48.8555, 48.8555
TM3p () - 44.125, 44.125
TM4a () - 48.3984, 48.3984
TMXP () - 46.625, 46.625
TPCD () - 53, 53
TS0V () - 41.3164, 41.3164
Tb0P () - 51.875, 51.875
Tb0p () - 51.875, 51.875
Tm0P (Mem Controller) - 46.75, 46.75
Tm0p () - 46.75, 46.75
Tm1P () - 47.25, 47.25
Tm1p () - 47.25, 47.25
Tm2P () - 52.5, 52.5
Tm2p () - 52.5, 52.5
Tp2F () - 42.9883, 42.9883
Tp2H () - 42.875, 42.875
Tp2h () - 42.875, 42.875
APPLE SSD SM0512F - 54
iMac15,1
Windows 8.1 x64
TC0c () - 55, 55
TC1c () - 55, 55
TC2c () - 53, 53
TC3c () - 54, 54
TCGc () - 56, 56
TCSc () - 55, 55
TG0d () - 68, 68
TG1d () - 63, 63
TH0A () - -1, 129
TH0B () - -1, 129
TH0C () - -1, 129
TH0F () - -1, 129
TH0O () - 9, 9
TH0P () - -1, 129
TH0R () - -1, 129
TH0a () - -1, 129
TH0b () - -1, 129
TH0c () - -1, 129
TH0e () - 1, 1
TH1C () - -1, 129
TH1O () - 9, 9
TH1P () - -1, 129
TH1c () - -1, 129
TL1P () - 39, 39
TL1p () - 39, 39
TM2P () - 42, 42
TM2p () - 42, 42
TPCD () - 53, 53
thinkbox
0. Thank you for the tech info.
1. Is the display resolution 3840x2160 under Windows? 125% DPI settings?
2. When you next time encounter this issue, please post here what is under
value
Maybe you only need to quit the app and start again (to reproduce it)
HKEY_CURRENT_USER\Software\CrystalIdea Software\Macs Fan Control\WindowPosition
