Bootcamp - unsuported hardware detected
Hi, I have a Mac Pro 1.1 (2006) with upgraded cpu Intel X5355, running Windows 7 64bit on bootcamp and getting unsuported hardware detected error.
Thanks in advance..
Thanks in advance..
Re: Bootcamp - unsuported hardware detected
daitarn
Please re-download the app, we updated it.
The error is still there (v1.3)..
daitarn
Does the setup process start?
No, just getting the error on computer startup/app startup
How did you install the app if the setup didn't started?
Oh sorry, the setup for installing went fine, I thought there was some kind of setup after first launching the app
daitarn
1. Could you please tell me what is under
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SystemInformation
SystemManufacturer?
2. Please download the latest build 202 and try running "MacsFanControl.exe" with /skipcheck command line parameter
SystemManufacturer?
1. Apple Computer, Inc.
P.S.: it says MacPro2,1, while it's a 1.1 to 2.1 firmware upgrade (maybe the firmware is the problem)
2...."try running "MacsFanControl.exe" with /skipcheck command line parameter" - Sorry, I worked on Macs for some 20 years, how do I do that?
Start -> Run -> cmd -> "C:\Program Files (x86)\Macs Fan Control\MacsFanControl.exe" /skipcheck
Oh, I didn't put the quotation marks.. now it opens and works fine, I changed the default rpms and everything works..
Do I have to run it every time with /skipcheck? It's not a big deal, but you could make a version that doesn't check for hardware compatibility, just for people who have problems and have compatible hardware, and give them the link to the that app here on the forum, at least you could spare yourself all the trouble of wasting your time on the support of a free app.
Anyway, thank you very much for your help, and especially for MacFanControl!
Cheers!
Cheers!
daitarn
Please run the app with /log command line parameter and send the log file (located in the app directory) it us.
I did that and there is no log file in the app folder, I even tried "C:\Program Files (x86)\Macs Fan Control\MacsFanControl.exe" /log >C: and gives me access denied, tried on desktop and some other folders but I always get a access denied warning..
Start -> Run -> cmd -> "C:\Program Files (x86)\Macs Fan Control\MacsFanControl.exe" /log
I did that, the app started with the usual unsupported hardware detected but there is no log file
C:\Program Files (x86)\Macs Fan Control\MacsFanControl.log
No, it's not there
daitarn
I think I fixed the problem. Please re-download the app (Build 203)
Yes, it works, thank you very much Steven for your support and help!
