I am one of the users running Mac OS 10.6.8 on the Mac side, and Windows 7 Pro SP1 32 bit via Bootcamp.
I understand that you've dropped support for OS 10.6.8 as of the current version - ah well, too bad...
My question: should I remain on version 1.2.1 on both operating systems (as I am now) or is it safe to run 1.3 under Windows, and 1.2.1 under the Mac OS provided the temperature and sensor settings are the same on both?
Should both installations be the same version?
Frank Lockwood
Mac Mini 6.2, 2.3 GHz. i7
Mac OS 10.8.5
Mac OS 10.8.5
Re: Should both installations be the same version?
fbl
You can absolutely use the latest version on Windows, it's OK.
PS. Why wouldn't you upgrade OS X ?
Thanks.Steven wrote:fbl
My older machines run more efficiently on the earlier OS.Steven wrote:PS. Why wouldn't you upgrade OS X ?
I'm concerned about the Backup Partition which Lion installs, screwing with my Bootcamp/Windows partition, as I don't have a lot of free space on my internal hard drive.
The version of ProTools, (v. Eight) which I use once in a blue moon, is incompatible with Lion.
It ain't broke.
Frank Lockwood
Mac OS 10.8.5
Mac OS 10.8.5
OK.
PS. Backup partition can be easily removed, google for it.
