Menu bar icon disappear on El Capitan
Quetzlacoatl
Post by Quetzlacoatl »
Hi! the app seems to work properly on El Cap GM, only one issue. the icon in the menu bar it's not visibile in the light and dark mode, it leave empty space between apps in the bar.
there's a workaround to resolve it or we must wait an update?
Re: Menu bar icon disappear on El Capitan
Quetzlacoatl
I'm downloading 10.11 GM to reproduce the issue.
Quetzlacoatl
I've just checked this issue with El Capitan final release, and it works fine
Quetzlacoatl
I've upgrade today and... the issue It's still here...
Any ideas?
Quetzlacoatl
Did you try to play with menubar settings in MFC ?
step19
Re: MFC 1.3.1 crash on OS X 10.11.0
Post by step19 »
Now there is a little cosmetic bug with icon on menubar (OSX 10.11.0): it is not created in any case. I tried to change icon with MFC preferences without success. This problem is not present on OSX 10.9.5 but I don't know about OSX 10.10.x.
Finally, I enclose logs for help about the problem of "excessive wakeups":
- MacsFanControl_2015-10-11-213551.wakeups_resource - generated by the system immediatly after the system startup
- Sample of MacsFanControl - generated with sample command (available on Activity Monitor)
Thank you for this great utility.
Ciao, Stefano.
Sample of MacsFanControl.diag.zip
(17 KiB) Downloaded 1910 times
MacsFanControl_2015-10-11-213551.wakeups_resource.diag.zip
(2.81 KiB) Downloaded 1896 times
step19
Thank you, will look into this
KeepItSimple
macs fan control 1.3.2.0
Post by KeepItSimple »
FYI
New version 1.3.2.0 as of 10/11/2015 the icon in the menu bar disappears in about 2 minutes in Lion 10.7.5
It will reappear if I double click on the application but disappears again.
step19
I reproduced the bug, working on it, thank you.
KeepItSimple
How to I reproduce it ? It doesn't disappear for me on 10.7 after 2 minutes...
andee
Re: macs fan control 1.3.2.0
Post by andee »
KeepItSimple wrote:FYI
Hi there. I had exactly this same problem (running 10.7.5), after upgrading from v1.3.0.
The solution (Remember to write down your previous preferences/settings before doing this!!!):
1) Delete the app from Application folder - Trash it!
2) Use a robust file mgmt utility (I use File Buddy), to locate all remnants of previous installation (like .plist files) - Trash 'em!
3) Re-download and install 1.3.2 again, input previous preferences (that you've written down) and you'll be as happy as Larry!
Hope this helps. Cheers!
Fixed in 1.4
