Hi all,
MFC 1.3.1 crash when "automatically hide and show the menu bar" is activated (System Preferences->General) and reboot the system.
User report log enclosed for help.
Another minor problem is marked on console reports without heavy applications running:
09/10/15 00:50:49,000 kernel[0]: process MacsFanControl[744] caught causing excessive wakeups. Observed wakeups rate (per sec): 1053; Maximum permitted wakeups rate (per sec): 150; Observation period: 300 seconds; Task lifetime number of wakeups: 45287
Ciao.
MFC 1.3.1 crash on OS X 10.11.0
- MacsFanControl_2015-10-09-004107.crash.zip
- (14.67 KiB) Downloaded 1043 times
Re: MFC 1.3.1 crash on OS X 10.11.0
step19
Thank you, I'm working on a fix right now.
Hey there!
Love the simplicity of your app, but been having a problem launching it since upgrading to 10.11 It looks like the same crash as step19, but it happens when I try to launch the app.
- MacsFanControl_2015-10-11-121224_Apple.crash.zip
- (14.48 KiB) Downloaded 863 times
Please try v 1.3.2
