language
language
When I downloaded the program there is no choice for a certain language although the program seems to be multilingual. But also during install there is no choice offered for a certain language. The program then installs in dutch. Well thank you for that Crystalidea because I am dutch and I live in The Netherlands but I would have preferred a choice. I want to post a problem with startup and I think I should do that in english by means of copy and paste the popup, but when I would do so I don't think you can make much of it. Now I have to post my problem in bad english. I hope it will be understood.
Re: language
There's a button in the AnyToISO main window called "Preferences", where you can select any language AnyToISO supports (Dutch is supported)
Re: language
I don't even know how the program looks like because it does not start. I get a popup with a text in dutch which I do understand, but when I woeuld paste it in a post here nobody would know what it means. But I already posted my startup problem with the popup translated in english.
