macs fan control on imac beachball
rkp
Post by rkp »
I had installed macs fan control successfully 5 days ago... now it sits in tray does not control fan speed and beachballs when I approach it. I uninstalled using mackeeper uninstall tool ..reloaded.. redownloaded and reinstalled. I have no other fan control software installed...reset smc...did a cmd/option PR reset...regardless of what I do it beachballs ..and eventually freezes other programs..then I need to restart..if I dont load macs fan control my computer has no problems but i need to wear ear muffs...
please help!!
rkp
Re: macs fan control on imac beachball
Post by rkp »
after running verify disc repair disc uninstalling and reinstalling still continues to "not responding"
see pic below
thanks
Screen Shot 2016-02-08 at 12.56.08 PM.png (168.08 KiB) Viewed 12388 times
rkp
Post by rkp »
11 views and no help.... That's disappointing:(
rkp
Can you please try cleaning MFC preferences by executing the following commands in Terminal?
killall MacsFanControl
rm ~/Library/Preferences/com.crystalidea.macsfancontrol.plist
killall -u `id -u -n` cfprefsd
rkp
Post by rkp »
Tried unsuccessfully :( this was the only product that worked for my problem
rkp
Post by rkp »
Are you able to tell me exactly where the command starts and stops?
rkp
Post by rkp »
here is screen shot of copy paste
Screen Shot 2016-02-12 at 10.04.56 AM.png (251.25 KiB) Viewed 12370 times
rkp
Post by rkp »
:D :Bravo: :good:
got it to work!!
thank you!!
