downloaded update and now the program doesn't launch and won't open.
running Mac OS 10.7.5
this is probably the third or fourth time that an update has caused problems. it would be good if old versions were kept on the site for download.
update disables macs fan control
Re: update disables macs fan control
actually I just re-downloaded and confirmed that this is the same error that has popped up a few times in the past. the program can run for about a minute, then crashes. in the past there has been a fix that can be employed for this, it would be good if this was included in every update from the beginning.
thanks
thanks
actually I'm sorry, but now it seems like the program is working fine. not sure what the problem was. I will observe for a day or so and report back if there are more crashes.
sorry for the trouble
