Macs Fan Control 1.4.1 - beta
Please post here your feedback, thanks.
+ Fan & sensor table width now can be changed with a splitter between them
* Bug fixes under Windows
Download for Mac
Download for Windows
caesun
Re: Macs Fan Control 1.4.1 - beta
Post by caesun »
Bug report.
Main UI, right pan, temperature sensors, does not display sensor values.
While 1.4.0 displays sensor values properly.
OS: Win 10 x64 (10.0.10586)
tech info:
MacBookPro11,4
CPU: Intel(R) Core(TM) i7-4770HQ CPU @ 2.20GHz [100]
GPU: Intel(R) Iris(TM) Pro Graphics 5200
Windows 10 x64
Left side-min{2160}curr{3488}max{6156}mode{2,TC1C,30,55}
Right side-min{2000}curr{2005}max{5700}mode{2,TC1C,39,49}
TB0T (Battery Max) - 26.1992, 26.1992
TB1T (Battery Sensor 1) - 25.7969, 25.7969
TB2T (Battery Sensor 2) - 26.1992, 26.1992
TBXT () - 26.1992, 26.1992
TC0E () - 40.5352, 40.5352
TC0F () - 42.4336, 42.4336
TC0P (CPU Proximity) - 35, 35
TC1C (CPU Core 2) - 41, 41
TC1F () - 41.3125, 41.3125
TC1f () - 41.3125, 41.3125
TC2C (CPU Core 3) - 38, 38
TC3C (CPU Core 4) - 40, 40
TC4C () - 40, 40
TCGC (GPU PECI) - 37, 37
TCMc () - -1, 0
TCSA () - 34, 34
TCTD () - 0.0507812, 0.0507812
TCXC (CPU PECI) - 41.2344, 41.2344
TCXM () - 41.3125, 41.3125
TCXP () - 41.2031, 41.2031
TH0A () - 33.125, 33.125
TH0B () - 32.125, 32.125
TH0C () - 29.125, 29.125
TH0F () - -1, 201.121
TH0R () - -1, 201.125
TH0V () - 28.0938, 28.0938
TH0a () - 33.125, 33.125
TH0b () - 32.125, 32.125
TH0c () - 29.125, 29.125
TH0x () - -1, 129
TM0P (Memory Proximity) - 37.625, 37.625
TM0S (Memory Slot) - 34.1719, 34.1719
TP0P () - 37.875, 37.875
TPCD (Platform Controller Hub Die) - 41, 41
TW0P (Airport Card) - 32.1875, 32.1875
Ta0P () - 27.875, 27.875
TaSP () - 27.875, 27.875
Th1H (Heatsink Proximity) - 31, 31
Th2H () - 30, 30
Ts0P (Palm Rest) - 25.3125, 25.3125
Ts0S () - 29.1562, 29.1562
Ts1P () - 24.5, 24.5
Ts1S () - 28.1719, 28.1719
APPLE SSD SM0256G - 30.125
caesun
Please re-download, must be fixed now.
caesun
Post by caesun »
The latest build works fine. Thank you.
MFC is the very tool I want when I do such jobs like video trans-coding, large data processing. I love it.
Two requests,
Is it possible to add more sensors for MacBookPro A1398. AIDA64 can display more sensors.
===============MFC technical info=======================
MacBookPro11,4
Windows 10 x64
Left side-min{2160}curr{2161}max{6156}mode{2,TCXC,60,96}
Right side-min{2000}curr{1994}max{5700}mode{2,TCXC,60,96}
TB0T (Battery Max) - 28.5, 28.5
TB1T (Battery Sensor 1) - 28.3984, 28.3984
TB2T (Battery Sensor 2) - 28.5, 28.5
TBXT () - 28.5, 28.5
TC0E () - 49.1133, 49.1133
TC0F () - 51.5625, 51.5625
TC0P (CPU Proximity) - 41.5, 41.5
TC1C (CPU Core 2) - 46, 46
TC1F () - 48.6562, 48.6562
TC1f () - 48.6562, 48.6562
TC2C (CPU Core 3) - 45, 45
TC3C (CPU Core 4) - 44, 44
TC4C () - 47, 47
TCGC (GPU PECI) - 46, 46
TCMc () - -1, 0
TCSA () - 43, 43
TCTD () - -1, 255.93
TCXC (CPU PECI) - 46.7969, 46.7969
TCXM () - 46.9219, 46.9219
TCXP () - 46.9844, 46.9844
TH0A () - 38.25, 38.25
TH0B () - 37.125, 37.125
TH0C () - 33.625, 33.625
TH0F () - -1, 205.625
TH0R () - -1, 205.625
TH0V () - 32.1406, 32.1406
TH0a () - 38.25, 38.25
TH0b () - 37.125, 37.125
TH0c () - 33.625, 33.625
TH0x () - -1, 129
TM0P (Memory Proximity) - 42, 42
TM0S (Memory Slot) - 39.3945, 39.3945
TP0P () - 43.125, 43.125
TPCD (Platform Controller Hub Die) - 46, 46
TW0P (Airport Card) - 38, 38
Ta0P () - 30.75, 30.75
TaSP () - 30.75, 30.75
Th1H (Heatsink Proximity) - 36.375, 36.375
Th2H () - 34.125, 34.125
Ts0P (Palm Rest) - 27.6875, 27.6875
Ts0S () - 33.0078, 33.0078
Ts1P () - 26.875, 26.875
Ts1S () - 31.7461, 31.7461
APPLE SSD SM0256G - 38.25
==================AIDA64=====================
Field Value
Sensor Properties
Sensor Type Apple SMC (Driver)
Temperatures
CPU 56 °C (132 °F)
CPU Package 64 °C (147 °F)
CPU IA Cores 64 °C (147 °F)
CPU GT Cores 62 °C (144 °F)
CPU #1 / Core #1 64 °C (147 °F)
CPU #1 / Core #2 61 °C (142 °F)
CPU #1 / Core #3 64 °C (147 °F)
CPU #1 / Core #4 62 °C (144 °F)
PCH Diode 53 °C (127 °F)
WLAN 43 °C (109 °F)
Battery 30 °C (86 °F)
DIMM 47 °C (117 °F)
Temperature #1 30 °C (86 °F)
Temperature #2 30 °C (86 °F)
Temperature #3 73 °C (163 °F)
Temperature #4 74 °C (166 °F)
Temperature #5 65 °C (148 °F)
Temperature #6 46 °C (115 °F)
Temperature #7 49 °C (120 °F)
Temperature #8 45 °C (113 °F)
Temperature #9 43 °C (110 °F)
Temperature #10 29 °C (84 °F)
Temperature #11 38 °C (101 °F)
Temperature #12 28 °C (83 °F)
Temperature #13 38 °C (100 °F)
APPLE SSD SM0256G [ TRIAL VERSION ]
Cooling Fans
Fan #1 2152 RPM
Fan #2 2003 RPM
Voltage Values
CPU Core 0.718 V
Battery 12.954 V
Power Values
CPU Package 17.99 W
CPU IA Cores 7.42 W
CPU GT Cores [ TRIAL VERSION ]
CPU Uncore 9.11 W
DIMM 1.42 W
Battery Charge Rate AC Line
Another request is, to the screen-shot above, I'd like to add some sensor-based values,
1. 'MAX_CPU_Temperature', maximum value of all CPU cores and GPU cores.
2. 'CPU usage', set fans speed based on CPU usage. A better solution is to add the correction based on chase temperature sensor.
Because at a certain environment, the CPU usage decides the heat output, a certain fan speed can bring out corresponding heat.
3. 'CPU power', in Watts, like AIDA64 shows.
caesun
We'll add more sensors in future versions, thanks
'MAX_CPU_Temperature' as well
tinyesp
Post by tinyesp »
Is there any reason that CPU Core 1 is missing from the report? Thanks.
