Can't hide icon app
Can't hide icon app
I can't unshow the icon app on menu bar. On configuration i can only change with success the temperature sensor displayed; app doesn't show the fans speed; and the icon always shows the black and white on menu bar, no matter the selected one. Tried to delete and install app again, but the preferences are saved in some file, so every time i install, preferences are all set when i open the app.
- Captura de ecrã 2016-04-20, às 17.29.44.png (86.36 KiB) Viewed 14346 times
Re: Can't hide icon app
reqjsp
There's no way to do that at the moment.
Are you saying that the Menubar Preference pane is not working as designed? If so, do you expect that it will be fixed in the near future?Steven wrote:reqjsp
Thank you for the great app.
MotionMan
reqjsp
I misunderstood you. Please update to the latest version of the app 1.4.2, it's fixed.
That fixed it.Steven wrote:reqjsp
MotionMan
