Error message at end of 1.4.3 installation
fbl
Post by fbl »
Under Win7 64 bit, logged on as Administrator, I quit the running version of MFC (1.4.2) and then ran the installer for 1.4.3. Everything appeared to proceed correctly but then I got an error message at the end of the process. Clicking "OK" dismissed the message, and as I had left the "Run MFC now" checkbox checked in the installer, MFC opened up normally. To test it, I rebooted my computer, and MFC 1.4.3 started automatically, as per my preferences setting.
Since everything seems to be working, is this message any cause for concern?
This window appears at the end of the installation process.
Installation Error Message.png (13.62 KiB) Viewed 22139 times
Frank Lockwood
Mac Mini 6.2, 2.3 GHz. i7
Mac OS 10.8.5
Re: Error message at end of 1.4.3 installation
fbl
It's not a big deal, but I'll look into this. Thanks!
fbl
Fixed in build 286, thanks again!
fbl
Post by fbl »
For the sake of clarification, does this mean you'll be issuing a new 1.4.3 release, or that this problem is so trivial it can wait until the next version?
Frank Lockwood
Mac OS 10.8.5
fbl
No, just new Windows build. Just re-download.
wolfo
Post by wolfo »
Still happenening after uninstalling 1.4.3 and downloading the latest version from your website (also 1.4.3).
Is the fix included in 1.4.3 or not?
http://forums.crystalidea.com/viewtopic.php?f=11&t=1464
