Sorry for my bad English.
Mac Fan Control is one of the best utility for control fans ever i see for Apple System,
but, no one! ever thinking about one FAN system, e.t all iMac models from 2012 to 2015 year include
one FAN system, to good sensetive controll between CPU - and - GPU for primary FAN.
what i mean:
Need a new option to control the speed FAN
for systems with one FAN,
this applies to models IMac 2012 - 2015 year
where the main SMC on board can not be adaptively quickly
control
the order (priority)
to control Are blowing.
this is a very negative impact on the GPU chip
Or CPU.
Control I offer developers Mac Fan
Make a new option for blowing priority
systems with one fan.
how it looks:
Senor available in the system which has
swap to make a priority:
IF Temperature CPU Diode => GPU Diode then Set Primary Status to Main FAN from (CPU Diode) and put User valus (Min) and (Max) to minimal and maximal values to sense (CPU Diode)
IF Temperature GPU Diode => CPU Diode then Set Primary Status to Main FAN from (GPU Diode) and put User valus (Min) and (Max) to minimal and maximal values to sense (GPU Diode)
Of course (Apple) has once again fail when removed HeatSink sensor
of new systems
system is based on Proximity whose values are sometimes not correct and timely.
Lets think about, one FAN system. iMac 2012-2015
FlashedBrain
