Ican't unisnstall a program
JBLl
Post by JBLl »
Using yor program, I select a program, and press unistall, but I get a new windows that says: The folder path 'C:' contains an invalid character
What can I do?
Re: Ican't unisnstall a program
The default uninstall program is probably corrupted. Can you try Force Removal?
JBLl
Post by JBLl »
Ok. I have do it, and It worked
