Hi Crystalidea,
I have some issues to connect wifi after ussing Macs Fan Control. Yesterday, I downloaded the app from Crystalidea.com, unzip the file and move the app to the application folder and run the app. The app works very good! However I unable to connect to internet.
Since I was unable to connect, I tried to forget my wifi and try to connect to the wifi again, but it says 'Unable to join..'. Then I tried to connect to my phone through personal hotspot, and it is connected.
At the same time, my ipad is connected to wifi and works perfectly.
I hope Crystalidea could give me any suggestions for my issue. This is not the first time, it was happened before and to solve it I reinstalled my laptop and I it is not possible for me to do reinstall again. Thank you.
Unable to connect wifi after install Macs Fan Control
stevenwaruwu
Re: Unable to connect wifi after install Macs Fan Control
The app does nothing to wifi. You can uninstall it to check.
