Version 1.4.8.1 on iMac11,1 running latest Sierra; in Preferences, when choosing "None" as the "Icon" under "Menubar display" does nothing, it does not disable the menubar item.
Bug: Disable menubar item does not work
Re: Bug: Disable menubar item does not work
There's no way to disable the menubar icon completely, something must be still displayed.
I'd also like to disable the icon completly. Wouldn't it be possible to show it under system settings (preferences?) instead?
Currently no, sorry. If the app is running, it's displayed in the menubar (at least with an icon)
pressurecooker
Then perhaps the option "None" could be removed from the preferences?Steven wrote:Currently no, sorry. If the app is running, it's displayed in the menubar (at least with an icon)
Well, the option "none" does indeed work, but only then, if you select another rpm or sensor first.pressurecooker wrote:Then perhaps the option "None" could be removed from the preferences?Steven wrote:Currently no, sorry. If the app is running, it's displayed in the menubar (at least with an icon)
For me it would be fine to access it via the launchpad and being able to disable all icons, but not a big deal.
