fanboy
[BUG] [SECURITY] Update feature does not use HTTPS
28 Nov 2017, 00:23
1.  The web site uses SSL but the in-app updater uses unencrypted port 80 HTTP transfers, making updates subject to MITM attack by malicious public access point
2.  Forum search feature seems broken:
"The following words in your search query were ignored because they are too common words: https update.
You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 14 characters excluding wildcards."
Re: [BUG] [SECURITY] Update feature does not use HTTPS
28 Nov 2017, 12:36
Will be fixed in the next update, thank you!
