Uninstall Tool can't handle environment variables like %systemroot% or %programfiles%.
So if uninstall string contains it - uninstall doesn't work.
Environment Variables
Re: Environment Variables
Lite
Hello, dear sir.
Thank you very much for the feedback. Can you please tell us which software to download in order to test it?
Hello, dear sir.
You can test it simply by imitating an installed program.
Simply use this ".reg" file:
This problem has been found when I try to uninstall "Synaptics TouchPad driver".
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Test Test]
"UninstallString"="%windir%\\system32\\calc.exe"
"DisplayName"="Test Test"
It's better late than never, will be fixed in 3.3
Fixed in 3.4 (currently in development): correct reading of REG_EXPAND_SZ registry values.
