I have an MDF image that windows XP displays as 704,996 KB (plus an MDS file); however, when I try and convert it to ISO, AnyToISO hangs at 99% (575MB written), with the progress displaying:
- Checking source image...
- Converting...
- Type 3, block size: 2448
Any clues?
File Extract/Convert to ISO
Re: File Extract/Convert to ISO
Midders
Could you please upload here this MDF (this is required for a quick fix)?
BTW: What is your AnyToISO version?
I've just uploaded the file 737.mdf.
At the moment I'm trialling AnyToISO Lite.
Thank you very much, just downloaded. Comments are coming
Midders
Thanks a lot for the feedback. The problem is solved in AnyToISO 3.3, the ISO file is OK
3.3 is not officially released yet, but you can download the fixed beta version from
http://www.crystalidea.com/downloads/anytoiso_beta.exe
Thank you for a quick response and resolution to the issue.
You're always welcome
