"This license grants you the right to use the software Uninstall Tool on multiple computers. In order to use the program on removable disks (portable version), registration data can be saved to the text file "license.dat" which can be stored into the program folder.
The data should be of the following format:
The first line - registration name
The second line - registration key
Example:
John Smith
KGT4-YGRT-GHTR-7G31"
Does this mean I have to create license.dat. It says "which can be stored into the program folder". Where is the program folder? I can't find license.dat either.
Where is licence.dat?
Re: Where is licence.dat?
longshot
You should create it by yourself. It's a plain text file with 2 lines
In what folder do I put it? Please don't just say the program folder.
The folder where UninstallTool.exe file is located
Thanks. Too bad it's not clearer. Or maybe I'm the dumbest guy on this forum.
