here are some, hopefully new, ideas to make your software even better:
- what about recompressing every ZIP file that is found in the profile (zip, jar, xpi) and reduce the compression level (or set to store only)? this will increase the profile size, but will reduce cpu time since the decompression will take less time...
- have you thought about integrating sysinternals contig for optimizing the filesystem of the profile?
- profile files could reduce your worktime, since the community is able to write and publish them in this forum.
[general] executable=path/to/ff/or/tb/or/other contig=path/to/contig enable-sqlite-opt=true enable-recompress=false enable-contig=true run-after-opt=true [sqlite] include=*.sqlite,*.db exclude=somefile.sqlite [recompress] compressionlevel=0 include=*.jar,*.zip,*.xpi exclude=somefile.xpi,otherfile.jar
