uninstall other programs
I am running Windows 7 64bit. I moved a bunch of programs from Windows XP used a program call PC Mover. Almost everything went okay. I'm trying to use uninstall tool to remove some of the junk that got transferred. The programs I want to remove are not on the add/remove list or uninstall tool list. I can see the program in one of the folders that got transfered. I can double click the icon and those programs run. I want to remove them but not sure how to get to them. Any help would be appreciatedl - Chuck
Re: uninstall other programs
Uninstall Tool removes only software in the program list.
Those programs you have you should remove manually by removing their folders.
If I just remove their folders won't there still be entrees in the registry?
Some settings of the software can be left in registry.
But good portable software (without installation) always use files to store settings.
