Going to "Properties > details", I noticed that the file version still states "2.0.0.62" instead of correct "2.0.1.63" (as already mentioned under product version).
This has some importance for programs like PSI by Secunia : at the moment, the detected version says "2.0.0.62" whilst the effectively used version obviously is "2.0.1.63".
Thank you !
Information in the "SpeedyFox.exe" file
Re: Information in the "SpeedyFox.exe" file
throkr
hi, it's not a bug, but will'll fix it in next builds.
Thank you.
Thank you.
