Install and Trace: Error 193
Re: Install and Trace: Error 193
Skrell
Thank you, looking forward to.
I'm experiencing the exact same problem. It apperars to be due to Install Tool not being able to handle spaces in the path to installer that is to be monitored.
As an example, I tried monitoring an installer in my C:\Users\User Name\Downloads folder and it failed. However, it worked when I copied the installer to C:\ and tried monitoring it from there. My Windows account name is made of two words, with a space seperating them. I would seem that Uninstall Tool is not able to handle the space being there. This is a problem for Windows too in some instances. For example, if open the Windows Run dialogue box, and enter C:\Users\User Name Windows is unable to open the folder. However if I enclose it in quotes, i.e. "C:\Users\User Name" the folder opens in Explorer.
Hi and thank you for the report!
But I don't think it's because of spaces.
1. Can you make a test and try the same uninstaller from
"C:\Folder"
and
"C:\Folder with space"
2. I think this error comes on some machines only from a certain folder.
What is the exact folder with the 193 error?
Thanks again.
"C:\Folder"
and
Thanks again.
Thanks for the quick reply. The monitoring is working from the folder with a space created in C:\.
The folder causing the problems is C:\Users\My Account\Downloads
It help to know that I was able to access the folder I created from the Run dialogue box by just entering the folder name C:\My Folder, but to open my user folder I needed quotes "C:\Users\User Folder".
roger_m
Just created a user called "User Name", logged in and successfully started Install Tracker from
C:\Users\User Name\Downloads\anytoiso_setup.exe
- Does your user name contain international characters?
- Are you using the latest version of UT (3.4.2)?
I'm only using letters, no international characters. I'm using the latest version.
Also, I'm using Windows 10 if that helps.
Does it happen when starting setup file from context menu only OR also when starting from the main UT window (Install and Trace button on the bottom toolbar)
I get the same error either way.
roger_m
Unfortunately this error 193 has never reproduced for years on our machines. We can prepaire a special (debug) version of the app to locate the problem.
Will you be able to test it?
PS. I'm 99% SURE It's actually a Windows bug related with CreateProcess function
Yes, most definitely,m that would be great.
roger_m
In progress, it will take a couple of hours
I'd be willing to try the debug version too !
roger_m
I have an idea. Do you have anti-virus installed (which one?)? If yes, please remove it, reboot and try again to start an .exe from the Downloads folder.
I know it's painful, you may try to disable its real-time protection first.
Skrell
Do you experience the same error?
Skrell
No, I don't use antivirus software at the moment.
Yes... Look back a page
roger_m
Skrell
Please use this test build. It will only produce a single DEBUG entry to the installation log (you can save it).
PS. The only thing that would help me to reproduce the issue is to have exactly the same Windows as you do.
And the only way to achieve it is to create a copy of your Windows drive using Disk2vhd utility. The disk image will contain your personal data, so please clean it by mounting the resulting .vhd file and removing all your data. Also I'd need a story how to reproduce the issue on this machine.
Yes it really sounds crazy
Skrell
- sshot-2015-05-22-[02-32-28].png (39.84 KiB) Viewed 29730 times
I'm not sure how this helps you but here is my log:
19:51:47 Starting Install Tracker service...
19:51:48 Service version is: 0x103
19:51:48 Starting KillerCleaner_32bit.exe...
19:51:48 DEBUG: C:\Documents and Settings\Administrator\Desktop\KillerCleaner_32bit.exe
19:51:48 Error: Cannot start the setup process (error 193)
19:51:48 Analyzing installation, please wait...
19:51:48 0 installation entries detected
That is what is happening for me too.
Skrell
roger_m
I'm sorry but I need a copy of the Windows drive to fix the problem (if it can be fixed)
(see my post above)
roger_m
(see my post above)
