Uninstall Tool 3.2 Beta
Download now (3.5 MB)
What's new:
- Batch Force Removal and Batch Remove Entry functions in Uninstaller
- Revert option in Install Tracker
- Improved compact view of apps list (see View->Compact List)
- Right-To-Left languages support (Arabic, Hebrew and Persian)
- Improved uninstall Wizard scanning: now faster and more accurate
- Improved registry items display in Uninstall Wizard
- Improved: even faster startup!
- Improved recent popup window
- Improved preferences window
- Improved: Startup Manager - checkboxes to enable/disable items
- Improved: program help is now online
- Startup Manager: fixed duplicate items on x64 systems
- Fixed saving of program preferences in some rare cases
- Fixed several false-positives in Uninstall Wizard scanning
- Uninstaller: fixed some rare crash when using Force Removal on some programs
- Uninstaller: improved look & feel of task pane when Windows themes are off
- Fixed some memory leaks
- Improved: Latvian & Croatian translations
Detailed builds history:
3.2.0.5270
- Improved help menu
- Check for beta version option (see Preferences)
3.2.0.5265
- Startup Manager: fixes in enable/disable items code, drawing fixes
- Startup Manager: use Space key to enable/disable items
- Uninstaller: fixed resizing of columns
- Uninstaller: fixed display of recent items in the secondary toolbar
- Uninstaller: recent items popup improved
3.2.0.5260
- Startup Manager: checkboxes to enable/disable items:
- Program help is now online
3.2.0.5256
- Fixed language selection from the View menu
3.2.0.5255
- Revert option in Install Tracker:
3.2.0.5250
- even faster startup, please check!
3.2.0.5246
- Compact view of apps list (see View->Compact List)
3.2.0.5245
- More cleaner removal of MSI products (Uninstall Wizard)
Note for translators: please wait for 3.2 final to update the language files. Thanks.
Kurbster
Re: Uninstall Tool 3.2 Beta
Post by Kurbster »
I seem to have a problem with using forced removal. Right after scanning for leftovers and OKing the results, I get a "Failed to connect to x64helper.exe process" error. After that, I get a message saying that this feature is only in the registered version. When I go to Help --> About, it says that I now have an unregistered version. Upon closing and restarting, it says I'm registered again
Kurbster
Thank you, will take a look at it
Kurbster
Fixed. Auto-update feature will notify beta users
eil
Post by eil »
Revert option means stop installation and clear all made changes?
yes
eil
Post by eil »
nice feature to have. :smile:
eil, thanks :smile:
More features are coming in 3.2, just didn't wanted to reveal everything in the beta.
Now thinking of a hotkey to stop (show the Stop dialog) the running installation. good?
Update: check your PM.
eil
Post by eil »
Steven, more features to be revealed is nice idea. ;) "stop"-hotkey should be good to have, but may raise a need for it to be customizable.
Ok, right.
eil
Post by eil »
have some visual glitches with Autorun when in non-fullscreen.
Wonneproppen
Post by Wonneproppen »
I have the problem that i can`t disable any checkboxes entries, also not with the right click function
Thanks, guys. Will fix it in the next build
Locked
