I am having problems with Chrome and for diagnostics purposes would like to undo the optimization I did with SpeedyFox.
Is there a way to do it?
That is, any and all changes SpeedyFox did to Chrome.
Undo SpeedyFox?
Re: Undo SpeedyFox?
No it's not possible.
rangergord
Re: Undo SpeedyFox?
Thanks for the reply.
OK, can I get back to a "pre-SpeedyFox" state by un-installing Chrome and doing clean re-Install of Chrome?
That is, un-install then remove the Chrome folder(s).
Re: Undo SpeedyFox?
There's 99.99999 % assurance that doing SQLITE VACUUM command doesn't influence the database contents.
That being said, SpeedyFox cannot modify your profile.
