Chromium profiles are apparently not recognized if they are not named "Default", Google Chrome and other Chromium Forks now allow for multiple profiles via the Settings > Users > Add New Users option.
Note: You can find a list of the Profile's names (which I believe defines the profile's folder's name) in the "…\Profiles\Local State" JSON file under "profile".
If you could add the ability to "Optimize!" these secondary profiles & installations without a "Default" profile I would be grateful.
~ UserName
P.S.: I only noticed this because I have a copy which I added a few profiles, gave them names, and removed the Default profile. Then I pointed SpeedyFox to the Profiles directory and it said:
P.P.S.: And now for something completely different:SpeedyFox was unable to detect any browser/supported program in the specified path (X:\…\Profiles).
If you're sure the path is correct and this profile should be supported by SpeedyFox, please use SpeedyFox support forum to let us know about the issue.
Shouldn't SeaMonkey profiles be listed under SeaMonkey (rather than Firefox) just like Iron isn't listed as Chrome (it's listed as Chromium/Iron)?
