Removing Office 2010
Currently using trial period. I'm unable to uninstall all of Microsoft Office 10. When forced uninstall is used a box comes up that wants you to buy it or the only other choice is to click close. The box goes away but when you click on uninstalltool to finish the box returns. A Circle of nothing happening is formed.
Re: Removing Office 2010
Uninstall Wizard doesn't remove traces in trial period, though saves for future the list of traces that can be removed in unlocked version.
