Is it possible to edit the logged filename of a traced program to better reflect this program after it has already been saved in "Uninstall Tool"?
I tried locating it in here:
C:\Users\USER NAME\AppData\Roaming\CrystalIdea Software\Uninstall Tool\Traced
and just edited the file name of the program I wanted to change (without messing up with the random numbers attached to logged files).
Is this correct?
Edit logged program names after the fact
Re: Edit logged program names after the fact
You cannot change a program name traced by Install Tracker if this program has been assigned itself to system registry. You can select a name of the traced item only if it's a custom entry (no entry in the HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall key).
