"The optimization process can take anywhere from 5 minutes to an hour"
The process on my computer takes less than 5 seconds, when run once a week.
Why not add command line parameters so I can include it in Startup and run it daily? That way I'll never forget, and always have FF optimized.
In the alternative, have a user selectable option to Run every __ days
Automate SpeedyFox
Re: Automate SpeedyFox
SpeedyFox has command line parameters, see menu Help for details.
"see menu Help for details."
What menu Help?
What menu Help?
Command Line Syntax
You can run SpeedyFox from command line using the following syntax:
/default_profile - optimize the default profile (most often case, when you have just one profile)
/profile:<name> - optimize a certain profile (you can find its name in the SpeedyFox profiles list combo)
/profile:path - optimize custom profile located at <path> (great for portable versions of SpeedyFox)
