Fan Control cant find HDD temperature (Windows)
mib
Post by mib »
Hi
I replaced my defect HDD in a iMac 10,1 (mid 2009) with a 2GB WD (WD20EZRX).
I now installed Win7 64bit in Bootcamp and found Mac Control to control the fan for me. I was very happy :D
However - the program do not detect the temperature of the HDD and therefore I cannot set it to a sensor based value.
Please advice if I need to do something?
PS: Other programs have detected the HDD temp via SMART so the hardware should be ok.
Re: Fan Control cant find HDD temperature
Do you see your new HDD in the list of sensors?
Please post a screenshot of Macs Fan Control.
mib
Post by mib »
Here a screenshot.
As you can see the CPU temp seems to be... a bit off.
Thank you, please also copy technical info from the about dialog here.
There's an issue in beta 4 - all items with 129 C value are incorrect, these sensors are not supported. Please ignore them for now.
The main problem I see here that your HDD is not supported :(
I will prepare today a special debugging version of Macs Fan Control to track the issue with not displaying of your new HDD. Please stay in touch. Thank you.
Update: BTW, what your GPU on this iMac?
mib
Post by mib »
I agree - only the HDD temp is of interest here :smile:
The graphics are GeForce9400
Tech info:
Machine:iMac10,1
Fans:ODD-min{996}curr{993}max{4333}mode{0}HDD-min{1095}curr{1494}max{6275}mode{1,1500}CPU-min{1195}curr{1194}max{3984}mode{0}
TempSensors:TA0P,TA0p,TC0C,TC0D,TC0H,TG0D,TG0H,TG0p,TH0O,TH1O,TL0P,TL0V,TL0p,TL1V,TL2V,TLAV,TLBV,TLCV,TN0D,TN0H,TN0P,TO0P,TO0p,TS0V,TS2V,Tm0P,Tm0p,Tp1P,Tp2H,Tp3H,Tp3v
Values:Ambient - 18,CPU Core 0 - 129,CPU Diode - 129,CPU Heatsink - 36,GPU Diode - 129,GPU Heatsink - 129,LCD proximity - 34,Northbridge Chip - 129,Northbridge Point 1 - 129,Optical Drive - 40,
Thank you! I'll post a testing version today!
mib
Post by mib »
Great - Thanks.
IMPORTANT QUESTION: have you tried mac version of Macs Fan Control on the same computer?
Let's try this now on Windows:
http://www.crystalidea.com/downloads/ma ... up_log.exe
It will produce 'log.txt' file, please post it here.
mib
Post by mib »
I use another fan control software for OS X.
The log file is:
INFO 2013-05-05T09:29:55.920 "Loading available SMART drives"
INFO 2013-05-05T09:29:55.920 "GetLogicalDrives returned 156"
INFO 2013-05-05T09:29:55.920 "Checking drive C:\"
INFO 2013-05-05T09:29:55.920 "Drive is fixed"
INFO 2013-05-05T09:29:55.920 "Phisical disk number: 0"
INFO 2013-05-05T09:29:55.992 "Checking drive D:\"
INFO 2013-05-05T09:29:55.992 "The drive is NOT fixed (5)"
INFO 2013-05-05T09:29:55.993 "Checking drive E:\"
INFO 2013-05-05T09:29:55.993 "Drive is fixed"
INFO 2013-05-05T09:29:55.993 "Phisical disk number: 0"
INFO 2013-05-05T09:29:55.993 "Checking drive H:\"
INFO 2013-05-05T09:29:55.993 "The drive is NOT fixed (2)"
mib
Post by mib »
I tried to use it on OS X. I have attached the screenshot.
Skærmbillede 2013-05-05 kl. 09.52.47.png (66.35 KiB) Viewed 104620 times
mib, according to the log - MFC for Windows must list your WDC now
mib
Post by mib »
I cant seem to find it...
Capture 05052013.PNG (51.05 KiB) Viewed 104615 times
Strange, I added more logging, please run it now
http://www.crystalidea.com/downloads/ma ... p_log2.exe
Please post a new log here.
mib
Post by mib »
INFO 2013-05-05T12:43:30.657 "Loading available SMART drives"
INFO 2013-05-05T12:43:30.657 "GetLogicalDrives returned 412"
INFO 2013-05-05T12:43:30.657 "Checking drive C:\"
INFO 2013-05-05T12:43:30.657 "Drive is fixed"
INFO 2013-05-05T12:43:30.658 "Phisical disk number: 0"
INFO 2013-05-05T12:43:30.733 "Adding drive \\.\PHYSICALDRIVE0"
INFO 2013-05-05T12:43:30.734 "Checking drive D:\"
INFO 2013-05-05T12:43:30.734 "The drive is NOT fixed (5)"
INFO 2013-05-05T12:43:30.734 "Checking drive E:\"
INFO 2013-05-05T12:43:30.734 "Drive is fixed"
INFO 2013-05-05T12:43:30.734 "Phisical disk number: 0"
INFO 2013-05-05T12:43:30.734 "Checking drive H:\"
INFO 2013-05-05T12:43:30.734 "The drive is NOT fixed (2)"
INFO 2013-05-05T12:43:30.735 "Checking drive I:\"
INFO 2013-05-05T12:43:30.735 "The drive is NOT fixed (2)"
I don't understand, really :o The drive is detected but doesn't appear in the list.
Added a lot of more logging now, give it a try please :smile:
http://www.crystalidea.com/downloads/ma ... p_log3.exe
mib
Post by mib »
INFO 2013-05-05T15:22:16.885 "Loading available SMART drives"
INFO 2013-05-05T15:22:16.885 "GetLogicalDrives returned 412"
INFO 2013-05-05T15:22:16.885 "Checking drive C:\"
INFO 2013-05-05T15:22:16.885 "Drive is fixed"
INFO 2013-05-05T15:22:16.885 "Phisical disk number: 0"
INFO 2013-05-05T15:22:16.927 "Adding drive \\.\PHYSICALDRIVE0"
INFO 2013-05-05T15:22:16.932 "Adding drive WDC WD20EZRX-00DC0B0"
INFO 2013-05-05T15:22:16.932 "Checking drive D:\"
INFO 2013-05-05T15:22:16.932 "The drive is NOT fixed (5)"
INFO 2013-05-05T15:22:16.932 "Checking drive E:\"
INFO 2013-05-05T15:22:16.932 "Drive is fixed"
INFO 2013-05-05T15:22:16.932 "Phisical disk number: 0"
INFO 2013-05-05T15:22:16.932 "Checking drive H:\"
INFO 2013-05-05T15:22:16.932 "The drive is NOT fixed (2)"
INFO 2013-05-05T15:22:16.932 "Checking drive I:\"
INFO 2013-05-05T15:22:16.933 "The drive is NOT fixed (2)"
INFO 2013-05-05T15:22:16.933 "QFanControl::Init: number of supported SMC sensors: 7"
INFO 2013-05-05T15:22:16.933 "QFanControl::Init: number of supported SMART sensors: 1"
This log is not complete, please post the full version
mib
Post by mib »
I checked the old log - and it only contained the above.
I uninstalled and installed again. Log file as follows:
INFO 2013-05-05T20:43:57.979 "Loading available SMART drives"
INFO 2013-05-05T20:43:57.979 "GetLogicalDrives returned 476"
INFO 2013-05-05T20:43:57.979 "Checking drive C:\"
INFO 2013-05-05T20:43:57.979 "Drive is fixed"
INFO 2013-05-05T20:43:57.979 "Phisical disk number: 0"
INFO 2013-05-05T20:43:58.044 "Adding drive \\.\PHYSICALDRIVE0"
INFO 2013-05-05T20:43:58.045 "Adding drive WDC WD20EZRX-00DC0B0"
INFO 2013-05-05T20:43:58.045 "Checking drive D:\"
INFO 2013-05-05T20:43:58.045 "The drive is NOT fixed (5)"
INFO 2013-05-05T20:43:58.046 "Checking drive E:\"
INFO 2013-05-05T20:43:58.046 "Drive is fixed"
INFO 2013-05-05T20:43:58.046 "Phisical disk number: 0"
INFO 2013-05-05T20:43:58.046 "Checking drive G:\"
INFO 2013-05-05T20:43:58.046 "Phisical disk number: 2"
INFO 2013-05-05T20:43:58.047 "Skipping USB drive"
INFO 2013-05-05T20:43:58.047 "Checking drive H:\"
INFO 2013-05-05T20:43:58.047 "The drive is NOT fixed (2)"
INFO 2013-05-05T20:43:58.047 "Checking drive I:\"
INFO 2013-05-05T20:43:58.047 "QFanControl::Init: number of supported SMC sensors: 7"
INFO 2013-05-05T20:43:58.047 "QFanControl::Init: number of supported SMART sensors: 1"
There should be log entries when the window populates the list of fans/sensors, quit the app, after that that the log must be complete.
Example:
INFO 2013-05-05T16:02:00.539 "QMySysInfo::machineName ('')"
INFO 2013-05-05T16:02:00.539 "Starting on iMac11,2"
INFO 2013-05-05T16:02:00.589 "QMySysInfo::machineName ('iMac11,2')"
INFO 2013-05-05T16:02:00.811 "Loading available SMART drives"
INFO 2013-05-05T16:02:00.811 "GetLogicalDrives returned 37356"
INFO 2013-05-05T16:02:00.811 "Checking drive C:\"
INFO 2013-05-05T16:02:00.811 "Drive is fixed"
INFO 2013-05-05T16:02:00.811 "Phisical disk number: 0"
INFO 2013-05-05T16:02:00.812 "Adding drive \\.\PHYSICALDRIVE0"
INFO 2013-05-05T16:02:00.812 "Adding drive M4-CT256M4SSD2"
INFO 2013-05-05T16:02:00.812 "Checking drive D:\"
INFO 2013-05-05T16:02:00.812 "Drive is fixed"
INFO 2013-05-05T16:02:00.812 "Phisical disk number: 1"
INFO 2013-05-05T16:02:00.813 "Adding drive \\.\PHYSICALDRIVE1"
INFO 2013-05-05T16:02:00.814 "Adding drive ST1000DM003-9YN162"
INFO 2013-05-05T16:02:00.814 "Checking drive F:\"
INFO 2013-05-05T16:02:00.814 "Drive is fixed"
INFO 2013-05-05T16:02:00.814 "Phisical disk number: 4"
INFO 2013-05-05T16:02:00.815 "Skipping USB drive"
INFO 2013-05-05T16:02:00.815 "Checking drive G:\"
INFO 2013-05-05T16:02:00.815 "Drive is fixed"
WARN 2013-05-05T16:02:00.815 "Failed to get IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS"
INFO 2013-05-05T16:02:00.815 "Checking drive H:\"
INFO 2013-05-05T16:02:00.815 "The drive is NOT fixed (5)"
INFO 2013-05-05T16:02:00.815 "Checking drive I:\"
INFO 2013-05-05T16:02:00.815 "The drive is NOT fixed (2)"
INFO 2013-05-05T16:02:00.815 "Checking drive M:\"
INFO 2013-05-05T16:02:00.816 "Phisical disk number: 0"
INFO 2013-05-05T16:02:00.816 "Checking drive P:\"
INFO 2013-05-05T16:02:00.816 "Drive is fixed"
WARN 2013-05-05T16:02:00.816 "Failed to get IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS"
INFO 2013-05-05T16:02:00.816 "QFanControl::Init: number of supported SMC sensors: 10"
INFO 2013-05-05T16:02:00.816 "QFanControl::Init: number of supported SMART sensors: 2"
INFO 2013-05-05T16:02:00.864 "QFanControlMainWindow::FillFansTable: number of fans: 3"
INFO 2013-05-05T16:02:00.864 "QFanControlMainWindow::FillFansTable: adding fan ODD"
INFO 2013-05-05T16:02:00.864 "QFanControlMainWindow::FillFansTable: adding fan HDD"
INFO 2013-05-05T16:02:00.864 "QFanControlMainWindow::FillFansTable: adding fan CPU"
INFO 2013-05-05T16:02:00.865 "QFanControlMainWindow::FillSensorsTable: number of supported sensors: 12"
INFO 2013-05-05T16:02:00.865 "QFanControlMainWindow::FillSensorsTable: adding sensor Ambient (TA0P)"
INFO 2013-05-05T16:02:00.865 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Core 0 (TC0C)"
INFO 2013-05-05T16:02:00.865 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Heatsink (TC0H)"
INFO 2013-05-05T16:02:00.866 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Core 1 (TC1C)"
INFO 2013-05-05T16:02:00.866 "QFanControlMainWindow::FillSensorsTable: adding sensor GPU Diode (TG0D)"
INFO 2013-05-05T16:02:00.866 "QFanControlMainWindow::FillSensorsTable: adding sensor GPU Heatsink (TG0H)"
INFO 2013-05-05T16:02:00.866 "QFanControlMainWindow::FillSensorsTable: adding sensor LCD proximity (TL0P)"
INFO 2013-05-05T16:02:00.866 "QFanControlMainWindow::FillSensorsTable: adding sensor Optical Drive (TO0P)"
INFO 2013-05-05T16:02:00.866 "QFanControlMainWindow::FillSensorsTable: adding sensor Mem Controller (Tm0P)"
INFO 2013-05-05T16:02:00.867 "QFanControlMainWindow::FillSensorsTable: adding sensor Power Supply Primary (Tp1P)"
INFO 2013-05-05T16:02:00.867 "QFanControlMainWindow::FillSensorsTable: adding sensor M4-CT256M4SSD2 (M4-CT256M4SSD2)"
INFO 2013-05-05T16:02:00.867 "QFanControlMainWindow::FillSensorsTable: adding sensor ST1000DM003-9YN162 (ST1000DM003-9YN162)"
mib
Post by mib »
Thats strange. I do not get any more in the log file even when I exit the program and restart it.
When I reinstalled the program I wondered why the speed of the fan was set to 1500 rpm. This was the setpoint I used on the "old" program, i.e. before I reinstalled the newest version of the program.
I am out of my league here, but is there a configuration file somewhere that needs to be reset?
The new installed program started very quick also - I do not suppose it was scanning a lot of adresses.
