CPU usage 3-24% on a MacPro 5.1 (beta 5)
prologos
Post by prologos »
Hello Forum
i have similar problems like "cfshelor" , at last with version 1.0 (Beta 5).
CPU usage was rising after 20 - 60 minutes between 3% - 24% (and then stays high)
This made me un instal the app, because its the only one witch heats my idle Mac up.
But I do like the idea, of sensor driven fans!!! Lots of thanks to the dev. Keep up the good work :-)
Question: Is the fixed Fanspeed a minimum Speed, witch increase automatic, when temp. is rising? So Apples Fan Control is still working?
best regard
prologos
MacPro 5.1 OSX 10.9.5
Re: CPU usage 3-24% on a MacPro 5.1 OSX 10.8.3
prologos
Did you try the latest version 1.0.1?
prologos
Post by prologos »
Hello Steven
nope until now. Should it solve the problem?
I hope yes
Please post a screenshot of the app please running on your Mac Pro
prologos
Post by prologos »
OK Steve, good News
New version is running about 2 hour now.
CPU is between 1,8 and 3 %
Memory is good also (see pics)
Thanks for this proper update
prologos
Ps. still my question about Constant rpm. Is it only the minimum, and incrasing when hotter? I dont like to damage some thing.
MFC BOOSTA.jpg (23.49 KiB) Viewed 29401 times
MFC 1.jpg (58.05 KiB) Viewed 29401 times
MacsFanControl start.jpg (37.87 KiB) Viewed 29401 times
thanks for screens!
Yes, it's always the value you set when setting constant value. Take care of temperature manually
prologos
Re: CPU usage 3-24% on a MacPro 5.1 (beta 5)
Post by prologos »
You would be a Mac Hero, if the option for "minimum speed" would also be intergrated ;)
But so far, since 2 weeks MFC is working fine, and no issue with unmounting a 2end HD !
thanks a lot for this great software
:smile:
CPU usage is now optimized even more in 1.0.4
