MEM Controller reading high
wildroverandy
Post by wildroverandy »
Firstly, thanks for a great product, it seems to work better than anything else I've tried, and is more sensitive to temperature changes than the standard built in control.
I do have one query. I have a Late 2009 model Mac Mini, running OS 10.8.3, with 8GB of RAM (maximum). All of the temperatures are reading about normal (in the 40-50deg C range), but the Mem Controller is showing 128deg C. It looks like it's stuck, rather than reading high. If I use this sensor to control the fans, it increases the fan speeds, and the other temperatures drop, but not this one.
I have tried checking this in iStatMenus, and that doesn't show this sensor at all - MFC picking up a false sensor reading?
Cheers
Andy.
Re: MEM Controller reading high
Yes it's a bug of MFC
Can you please share MFC window screenshot? so we can track and fix the issue
wildroverandy
That's fine, it's good to know at least I don't have a fault on my Mac.
I've attached a screen grab showing the Mem Controller at 128C immediately after waking from sleep.
Andy.
MFC Grab.jpg (71.26 KiB) Viewed 16097 times
Thank you, just added this fix, it will be available in the next update
wildroverandy
Thank you, all fixed now. Can't see anything else :smile:
