-----------------------------------------------------------------------------------------Open Comodo Internet Security and click on Defense+ tab, click on Defense+ Settings, then click on the Execution Control Settings tab and click on Exclusions at Detect shellcode injections, Click add->browse add the file C:\Program Files\Uninstall Tool\utool.exe and click Apply, Apply, ok.Now you can launch the Uninstall tool.
Downloaded trial version of 'Uninstall Tool' (version 2.9.7) from Crystalidea website.
Download installed successfully.
When application is executed (run) by double clicking 'Uninstall Tool' icon on desktop, the startup screen is displayed only for a moment.
A brief glimse of the opening screen is seen and then disappears.
Can't uninstall 'Uninstall Tool' as the option to replace 'Add or Remove Programs' was allowed during the third installation.
Can't find any reference to this problem in forum discussions.
Using Windows XP Pro (SP3) on a Dell Dimension 8300.
Above problem occurred twice before when downloading and installing 'Uninstall Tool'.
Twice it was installed and removed, before allowing replacement of 'Add or Remove Programs' on third attempt.
Re-downloading , re-installing, and re-running made no change in the problem described above.
It appears everything is normal but can't utilize 'Uninstall Tool' because opening screen won't stay displayed.
