	RPM Problem
						RPM Problem
			It says that my minimum RPM is 1992, and it's currently at 1983. Is this normal for a MacBook Pro? I thought the minimum was at 2000.
Re: RPM Problem
Yes it's normal
						Re: RPM Problem
Thank you so much. I was extremely worried that I messed up some internal files trying to find a correct fan control application!
