Hey guys!
i have a little question: Is it possible to save my sensor based Configuration?
I am asking, because in a few Months I will receive the old iMac early 2006 20" with graphic card problems
and actually they are using application SMC Fan control to prevent the iMac from overheating.
I want to use the iMac as a Media Center and I don't like to control the fans manually, so i would like to use the feature in Macs Fan Control, but with saving the set Temps!
THX.
Saving the sensor based Control?
Re: Saving the sensor based Control?
I'm afraid i didn't get the idea. MFC saves fans controlling configuration. When you quit the app / reboot iMac, MFC will start using the previous configuration.
Or do you want to transfer configuration from one machine to another?
Thanks Steven! No I don't want to transfer the configuration, but it's an IdeaSteven wrote:Hi,
Uhm, but it wont start automatically at login!
In the settings I hooked "Autostart minimized"
What is the mac version?
i've got Mountain Lion and Macs Fan Control 1.1.5
Did you copy MFC to Applications?
If yes, try enable/disable of autostart again. If it doesn't help, add MFC to Startup items manually.
My last question: does it work with 10.9 Mavericks?
