Despite the 2.0.8 version, it's still not possible to optimize Firefox...
I'm running Vista 32.
Cannot optimize...
Cannot optimize...
- Error message.
- 000024.jpg (122.7 KiB) Viewed 38085 times
- Printscreen of running processes BEFORE launching Speedyfox.
- 000023.jpg (234.69 KiB) Viewed 38085 times
Re: Cannot optimize...
toto789
Can you send us signons.sqlite file?
I' m a bit reluctant sending this file as it contains sensitive data...
Anyway, when I try to open it with Notepad, I got a warning "Access is denied"
toto789
then it really means that it's in use by some program (Firefox)
I check the file with "Unlocker 1.83" program, and it shows no running process using it...
Hello toto789,
Have you tried also killing the "plugin_container.exe *32" process as well, it's also a Firefox process.
Edit: oops just noticed how old this thread was.
