Uninstall Tool 3.0 Beta
Re: Uninstall Tool 3.0 Preview Release
Build 3.0.0.5165:
- Support of modern fonts (Vista/7) in all dialogs
- Uninstall Wizard: fixed removing of registry values containing '\' in their names
A little time is left for Install Tracker !
Thank you Steven, meanwhile I'm going to test 3.0.0.5165
Thank you, I be tester
Thank you very much for the excellent program! it works very stable. really want to see the program to add software hand. Ie stated. exe and then the program will automatically find all.
thanks in advance
thanks in advance
Trashe1
Thanks for the proposal, that's a nice feature, will definitely consider adding it to 3.x versions.
I'm working on translating the program into Russian
later lay language file.
Trashe1
Russian translation is not required, sir: we already have a translator.
BTW: Localization will be available in next builds.
then wait for the next builds
I was interesting to try their hand at translation
Can i translate UT to catalan?
of course you can complete english.xls is open notepad and fix it for themselvesRafel wrote:Can i translate UT to catalan?
Rafel
Of cause! but only when official English.xml for 3.0 is ready (in next builds)
Ok, i'll be waiting.
could you do so in the demo version of the program was given a certain period to test it? I now remove the program through her and she offers it to me to buy (register was not cleared: (
Trial/Full version limitations are under thinking over, maybe 3.0 licensing schema will be improved.
Trashe1, private questions should be asked in personal messages.
with surprise found that there are already another uninstaller with "Real-Time
Installation Monitor" (no names or it's sound like advertising). still i don't like its interface and name.
Uninstall Tool was always good-looking, swift and comfortable. good thing is worth waiting for
eil
We'are aware of competitors, and we're better.
as soon wait for the new version?
If the program starts to move away from Utool not, the standard method is not yutul clears after the registry and all that remained of the program. this would suggest that Utool hung in the background and remove programs not monitored by Utool. and if the removal is without Utool opened window cleaning after removal.
Sorry me for my english
Trashe1, either i don't understand something, or it's little meaning in these abilities.. what's their points?
Trashe1, If I understand you right, you suggest some soft of resident process. Actually we do not see much sense of it at the moment or.. please be more specific.
What concerns next 3.0 build, there's a good news: next build will be "3.0 Beta" with first version of Install Tracker on board. In 1-2 weeks
Update: Uninstall Wizard informs of files in use:
does such view of window means there will be no 2.x "leftover"-style anymore? and do those files can't be deleted at a moment, and really need reboot?
The 2.x leftover style remains, this window is displayed just for information if some files are in use by the system (in 2.x the user was unaware of that).
Reboot is optional, of cause.
