When I start up my Mac using OSX the minimum fan speed is normally 1500 rpm.
Unless it was previously booted as a PC (running Windows version of the your software), then it can be 2000 rpm or 1700 rpm.
Attached file has "copy technical info" from 1500, 1700, 2000 rpm results taken directly after startup
Different minimum RPM
- t1.txt
- (4.45 KiB) Downloaded 663 times
- Screen Shot 2014-05-16 at 6.36.21 .PNG (51.75 KiB) Viewed 6457 times
Re: Different minimum RPM
mkaz
Minimum speed for this mac is 1500.
MFC never changes minimum fan speed thus it can be either other fan controlling software or Mac uses different settings for Windows & mac.
