Read only mode: non-Apple file system detected (smbfs)
picman
Post by picman »
Hi, i have install Mac fans in the Applications Dir, but still getting this message.. any idea's?
I have parallels on my machine but not running.
screen shot
screen shot
Screen Shot.jpg (243.08 KiB) Viewed 10487 times
Re: Read only mode: non-Apple file system detected (smbfs)
picman
Please paste the output of the following command in Terminal:
diskutil list
picman
Post by picman »
nicks-iMac:~ nick$ diskutil list
/dev/disk0
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *500.1 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_HFS OSX 499.8 GB disk0s2
picman
Post by picman »
Ok i figured it out:
When i have drives mounted from my windows box as network drives it wont work?
When i dissconnect the drives it then works????
Help
I need to have the shared drives mounted....
can you try?
picman
Post by picman »
Can i try what?
When i dissconnect the drives, then mac fan control works fine, but when the drives are connected i get the error shown above..
picman
How do you connect/disconnect the drive(s) so I can reproduce the issue?
