Whenever I start up windows now, there are always two instances of Macs Fan Control in the system tray, and I have to manually quit one. This seems to cause a system crash if I suspend, so that's why I kill the second process. Uninstalling Macs Fan Control doesn't seem to fix it, so I'm guessing it's a registry entry somewhere? Techical info below... Thanks,
Macs Fan Control 1.1.12.2, MacBookPro9,1, Windows 7
Left side-min{2000}curr{2220}max{6200}mode{2,TC1C,60,80}
Right side-min{2000}curr{2207}max{6200}mode{2,TC1C,60,80}
TA0P (Ambient) - 42.25
TB0T (Battery TS_MAX) - 34.6992
TB1T (Battery Point 1) - 34.6992
TB2T (Battery Point 2) - 34.0977
TC0E () - 64.75
TC0F () - 66.1172
TC0P (CPU Proximity) - 55.25
TC1C (CPU Core 1) - 61
TC2C () - 62
TC3C () - 65
TC4C () - 63
TCGC (PECI GPU) - 60
TCSA () - 63
TCXC () - 65.3594
TG0D (GPU Diode) - 58.5
TG0P () - 54.125
TG1D () - 60
TG1F () - 59.832
TG1d () - 54
TGTC () - 0.125
TGTD () - 0.0234375
TM0P () - 43.125
TM0S (DIMM Module 1) - 50.2969
TP0P () - 44.25
TPCD () - 73
Th1H () - 51.75
Th2H () - 49.125
Ts0P (Left Palm Rest) - 33.1875
Ts0S () - 42.0664
Ts1S () - 42.0664
Tsqf () - 47.0938
Multiple instances of Macs Fan Control in system tray
Re: Multiple instances of Macs Fan Control in system tray
Rodan
Please export to HTML (File -> Export) of Uninstall Tool startup manager:
http://crystalidea.com/manage-startup-programs-windows
and post this html here.
I tried to attach the html file, but it wouldn't let me, so here's a copy paste. It's strange that, although Macs Fan Control is running, it's not in this list?
Startup Programs
Generated by Uninstall Tool 3.4 on Sunday, September 14, 2014 9:17:36 AM
SESAME
Program Name Status Source Company
Adobe Reader and Acrobat Manager Running HKLM Run Adobe Systems Incorporated
Avira Running HKLM Run Avira Operations GmbH & Co. KG
Avira system tray application Running HKLM Run Avira Operations GmbH & Co. KG
Boot Camp Manager Running HKLM Run Apple Inc.
Brother Status Monitor Application Running HKLM Run Brother Industries, Ltd.
Google Drive Running HKCU Run Google
Intel(R) USB 3.0 Monitor Running HKLM Run Intel Corporation
Intuit Data Protect Not Running StartMenu All Intuit Inc.
Microsoft Office 2010 component Not Running HKLM Run Microsoft Corporation
Skype Running HKCU Run Skype Technologies S.A.
10 programs total, 8 are currently running
Startup Programs
SESAME
Are both icons in system tray working? I mean are there really 2 processes "MacsFanControl.exe" running?
That's correct. I just habitually go to the system tray, right click, and close one of them on every system startup. Thought I'd finally send a message about it
I have attached 2 pictures, one that shows the system processes, where you can see the 2 instances of Macs Fan Control, and the other showing the 2 icons for Macs Fan Control in the system tray. Any ideas? Thanks,
- photo(1).JPG (143.31 KiB) Viewed 11552 times
- Capture.PNG (83.71 KiB) Viewed 11552 times
Rodan
Thanks for pictures. Actually I have only one idea.
Check number of tasks at Windows Scheduler:
http://www.howtogeek.com/school/using-w ... sson2/all/
