I recently built a SSD into my iMac 27inch 2011. I placed it behind the Optical drive and attached it to the 3rd SATA connection.
When I booted from the SSD first time the fans were going crazy.
Anyway this is a known issue. I'm pretty sure that I did not damage anything.
Macs Fan Control helped me to solve this annoyance - THANKS!
But there is one thing that is keeping me puzzled.
I have MFC as startup item. In the beginning after shutting down and unplugging my iMac ( I do that overnight) the fans raved up again. Having a look at the preferences I saw that almost all sensors where gone and the fan- preferences where switched back to 'Auto'.
Restarting MFC resolved the issue.
Have a look at the logs before and after restarting MFC.
INFO 2014-09-26T08:38:12.152 MacFanControl/app.cpp @ 154 "Macs Fan Control 1.2.0 beta"
INFO 2014-09-26T08:38:12.153 MacFanControl/app.cpp @ 155 "Mac OS X 10.8"
INFO 2014-09-26T08:38:12.153 MacFanControl/app.cpp @ 156 "iMac12,2"
INFO 2014-09-26T08:38:12.153 MacFanControl/app.cpp @ 157 "Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz"
INFO 2014-09-26T08:38:12.153 MacFanControl/app.cpp @ 158 "Qt 5.3.1"
INFO 2014-09-26T08:38:12.979 MacFanControl/core/FanControl.cpp @ 436 "QFanControl::Init"
INFO 2014-09-26T08:38:12.979 MacFanControl/core/FanControl.cpp @ 450 "QFanControl::Init - LoadCachedFansAndTempSensors"
INFO 2014-09-26T08:38:12.980 MacFanControl/core/FanControl.cpp @ 455 "QFanControl::Init - FilterSupportedTempSensors"
WARN 2014-09-26T08:38:12.982 MacFanControl/core/FanControl.cpp @ 343 "FilterSupportedTempSensors - skipping sensor TA0P with value of 0"
WARN 2014-09-26T08:38:12.983 MacFanControl/core/FanControl.cpp @ 343 "FilterSupportedTempSensors - skipping sensor TC0H with value of 0"
WARN 2014-09-26T08:38:12.985 MacFanControl/core/FanControl.cpp @ 343 "FilterSupportedTempSensors - skipping sensor TC0P with value of 0"
WARN 2014-09-26T08:38:12.987 MacFanControl/core/FanControl.cpp @ 179 "smc_get_temp - skipping sensor TG0D with value of 129"
WARN 2014-09-26T08:38:12.987 MacFanControl/core/FanControl.cpp @ 343 "FilterSupportedTempSensors - skipping sensor TG0D with value of -1"
WARN 2014-09-26T08:38:12.988 MacFanControl/core/FanControl.cpp @ 343 "FilterSupportedTempSensors - skipping sensor TG0H with value of 0"
WARN 2014-09-26T08:38:12.990 MacFanControl/core/FanControl.cpp @ 343 "FilterSupportedTempSensors - skipping sensor TL0P with value of 0"
WARN 2014-09-26T08:38:12.992 MacFanControl/core/FanControl.cpp @ 343 "FilterSupportedTempSensors - skipping sensor TO0P with value of 0"
WARN 2014-09-26T08:38:12.994 MacFanControl/core/FanControl.cpp @ 343 "FilterSupportedTempSensors - skipping sensor Tm0P with value of 0"
WARN 2014-09-26T08:38:12.996 MacFanControl/core/FanControl.cpp @ 343 "FilterSupportedTempSensors - skipping sensor Tp3H with value of 0"
INFO 2014-09-26T08:38:12.996 MacFanControl/core/FanControl.cpp @ 459 "QFanControl::Init - smc_get_fans_control_mode"
INFO 2014-09-26T08:38:12.998 MacFanControl/core/FanControl.cpp @ 96 "Fan " 0 ": auto"
INFO 2014-09-26T08:38:12.998 MacFanControl/core/FanControl.cpp @ 96 "Fan " 1 ": auto"
INFO 2014-09-26T08:38:12.998 MacFanControl/core/FanControl.cpp @ 96 "Fan " 2 ": auto"
INFO 2014-09-26T08:38:12.998 MacFanControl/core/FanControl.cpp @ 463 "QFanControl::Init - QTempSensorSmart::LoadAvailableSensors"
INFO 2014-09-26T08:38:13.003 MacFanControl/core/FanControl.cpp @ 467 "QFanControl::Init: number of supported SMC sensors: 0"
INFO 2014-09-26T08:38:13.003 MacFanControl/core/FanControl.cpp @ 468 "QFanControl::Init: number of supported SMART sensors: 2" Code: Select all
INFO 2014-09-26T11:20:49.985 MacFanControl/app.cpp @ 154 "Macs Fan Control 1.2.0 beta"
INFO 2014-09-26T11:20:49.985 MacFanControl/app.cpp @ 155 "Mac OS X 10.8"
INFO 2014-09-26T11:20:49.985 MacFanControl/app.cpp @ 156 "iMac12,2"
INFO 2014-09-26T11:20:49.985 MacFanControl/app.cpp @ 157 "Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz"
INFO 2014-09-26T11:20:49.985 MacFanControl/app.cpp @ 158 "Qt 5.3.1"
INFO 2014-09-26T11:20:50.244 MacFanControl/core/FanControl.cpp @ 436 "QFanControl::Init"
INFO 2014-09-26T11:20:50.244 MacFanControl/core/FanControl.cpp @ 450 "QFanControl::Init - LoadCachedFansAndTempSensors"
INFO 2014-09-26T11:20:50.244 MacFanControl/core/FanControl.cpp @ 455 "QFanControl::Init - FilterSupportedTempSensors"
INFO 2014-09-26T11:20:50.258 MacFanControl/core/FanControl.cpp @ 459 "QFanControl::Init - smc_get_fans_control_mode"
INFO 2014-09-26T11:20:50.259 MacFanControl/core/FanControl.cpp @ 96 "Fan " 0 ": auto"
INFO 2014-09-26T11:20:50.259 MacFanControl/core/FanControl.cpp @ 96 "Fan " 1 ": auto"
INFO 2014-09-26T11:20:50.259 MacFanControl/core/FanControl.cpp @ 96 "Fan " 2 ": auto"
INFO 2014-09-26T11:20:50.259 MacFanControl/core/FanControl.cpp @ 463 "QFanControl::Init - QTempSensorSmart::LoadAvailableSensors"
INFO 2014-09-26T11:20:50.266 MacFanControl/core/FanControl.cpp @ 467 "QFanControl::Init: number of supported SMC sensors: 9"
INFO 2014-09-26T11:20:50.266 MacFanControl/core/FanControl.cpp @ 468 "QFanControl::Init: number of supported SMART sensors: 2"
Meanwhile this behaviour of MFC persists, but strangely enough the fans stay quiet and at normal speed.
So there is not really a problem anymore, right?
I really would like to know what happened and what I can do to make the fan- preferences and sensors make 'stick'.
Thanks in advance.
Clemens
