Hi Crystalideas thanks for a superb dual OS app. I refer your app to everyone as a Mac/Windows IT consultant/Engineer.
I have run into a slight problem though - MFC was running happily on my own Mac Pro 3,1 8 core but since I have migrated onto a flashed 4,1 (5,1) Mac Pro the app still reports I am using a Mac Pro 3,1.
I have tried an uninstall, reboot and reinstall yet it still reports mine as a 3,1. I suspect its remants of config files left after the uninstall which is giving the incorrect detection. Could you be so kind to give me the locations for me to manually remove any files so MVC can detect my Mac Pro to the correct model please, on Windows 7 64 bit.
Thanks in advance.
Uninstall cleanup for Windows after Mac Pro upgrade
Re: Uninstall cleanup for Windows after Mac Pro upgrade
Please clean up this registry key:
HKEY_CURRENT_USER\Software\CrystalIdea Software\Macs Fan Control
Many thanks for the quick reply and tip.
Worked a treat thanks Steven
