Hello anyone
I have cases:
First I am go to traced the "1setup.exe", using install and trace, while in the process...I lunch the "2setup.exe" or "3setup.exe" without traced it!...
When 1setup.exe finish, it show its traced data and also 2setup.exe and 3setup.exe traced data's too....the problems is: when we want to uninstall the 1setup.exe only! the 2 and 3setup also removed. YES we can use the check and uncheck box on list of traced data! but it takes times! Isn't?
So can the developer isolate the 1setup.exe only to traced....
because time is matter...
Regards
Zilzal
