Version 2.0.9.75 Not Working on XP Pro
Top popular freeware SpeedyFox
wpr4
Post by wpr4 »
I just downloaded the newest version and when I double click it nothing happens. No boxes or messages or anything. The prior version works fine.
Does this version not work on XP Pro?
Thanks for any comments and/or suggestions.
Re: Version 2.0.9.75 Not Working on XP Pro
Please try build 76 (the latest version)
wpr4
Post by wpr4 »
Thank you for your reply.
I just downloaded and ran the latest version, but it resulted in an Unhandled Exception.
I selected the option to send the report, but I do not know if that worked, so I'm attaching the Unhandled Exception dump file.
speedyfox.exe_2.0.9.76_5.1_x86_2014-12-31_11.58.48.zip
(7.74 KiB) Downloaded 8772 times
wpr4
Thank you for the report! Which CPU do you have?
Please try build 77 (re-download)
wpr4
Post by wpr4 »
I downloaded build 77 and got the same Unhandled Exception error box.
My CPU is an AMD Athlon MP Palomino.
wpr4
Please try build 78, I've disabled SSE2 cpu extensions
Bobblink
Post by Bobblink »
Thanks Steven.
I was having the same problem on my old 1.2GHz Celeron (no sniggering please :oops: )
The latest build works just fine, thank you.
