Launching the application now provides a "Not a valid Win32 application" error.
This issue is very likely linked with the update to Visual Studio 2013 version which does not target Windows XP by default. This can be solved at compilation time.
Everything works fine on previous version.
Kind regards.
Chano22000
Macs Fan Control 1.1.12.3 does not work anymore on Wndows XP
chano22000
Re: Macs Fan Control 1.1.12.3 does not work anymore on Wndows XP
Thank you for the report. Please re-download, should be fixed.
