Auto mode working in Windows 10 Preview
halasz
Post by halasz »
I am running Windows 10 Preview in Bootcamp and have noticed that the Auto mode always leaves the fans on minimum.
Here is an example (playing Asphalt 8). Note the log says Windows 8.1 but it is not it is Windows 10 build 9936 (x64).
I know Windows 10 is beta and not released but thought it might be interesting none the less.
Macs Fan Control.png (52.84 KiB) Viewed 11850 times
MacsFanControl.log
(2.85 KiB) Downloaded 1113 times
Technical Info.txt
(1.04 KiB) Downloaded 1167 times
Re: Auto mode not working in Windows 10 Preview
halasz
Try to heat up CPU to 100C (all 4 cores) and see
not working
It might be working correctly
halasz
Post by halasz »
Steven wrote:halasz
not working
You are correct - it does work, sorry. The fans start speeding up at 100C. It is a little close to shutdown temperature though (for me, perhaps I worry too much) and the default values for sensors result in fans speeding up at much lower temperatures.
Is it documented anywhere what the Auto setting algorithm is?
Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
TJMax T (C): 105
Running Prime 95...
100 degrees.png (53.28 KiB) Viewed 11844 times
Later on.PNG (53.02 KiB) Viewed 11843 times
halasz
Re: Auto mode working in Windows 10 Preview
Post by halasz »
I've changed the thread title from "not working" to "working" btw as it is :oops:
No it's not documented.
