Could you add Slimjet in speedyfox ?
It is based on Chromium 32 & 64.
Slimjet
Slimjet
BerniceJenkins
Re: Slimjet
Slimjet is Chromium based so it can just be added manually. I have already been doing this for a while. Just click on the Speedyfox drop down menu and scroll down to add custom profile. Then navigate to the user data folder for Slimjet when the window pops up. Its in the same place the one for Chrome is except rather then going to the Chrome folder go to the Slimjet folder and then to that user data folder.
Re: Slimjet
Noruas
BerniceJenkins
Please download the latest version of SpeedyFox with support of Slimjet
BerniceJenkins
BerniceJenkins
Re: Slimjet
Steven wrote:Noruas
BerniceJenkins
I thought I did have the latest version. The website says version 2.0.13 but the download is actually 2.0.14. Not sure if you noticed that. That is why I had no idea I was not using the latest one.
Your Firefox/Skype/Chrome/Thunderbird is working slowly?
Boost them all in a single click with SpeedyFox absolutely for free!
You get:
Boost Startup in up to 3 times!
Speed-up browsing history
Overall quicker operation
Smaller profile size
Supported Apps: Firefox, Chrome, Epic, Iron, Opera, Palemoon, Skype, Thunderbird, Yandex, Cyberfox
Download: (version 2.0.13)
SpeedyFox for Windows (671.54 KB)
SpeedyFox for Mac OS X (822.36 KB) (Firefox only, Universal binary)
Re: Slimjet
BerniceJenkins
the page was cached, please check it now.
999qwerty777
Re: Slimjet
Can slimjet portable be added? portable version available from slimjet from
http://www.slimjet.com/en/postdl.php?ve ... 2&type=zip
http://www.slimjet.com/en/postdl.php?ve ... 4&type=zip
