What settings would you use on an iMac (27", mid 2011) for HDD fan and ODD fan?
(I would use it as automatic but my right skin temp sensor is broken and sometimes make the ODD fan run at full speed).
At this moment, I'm using it like this.
ODD fan -> Based on GPU Heatsink (50º, max. 65º).
HDD fan -> Auto.
CPU fan -> Auto.
Perfect settings for iMac (27", mid 2011)
Re: Perfect settings for iMac (27", mid 2011)
Looks correctly but I'd increase max value (e.g. to 80). Google for max GPU temperatures for you model
antoniokratos
I've been searching for it and I haven't found anything useful, but I've set the max value pro GPU Heatsink at 75º.Steven wrote:Looks correctly but I'd increase max value (e.g. to 80). Google for max GPU temperatures for you model
